ExtCursor Constructor
Overload List
| Overload | Description |
| ExtCursor Constructor() | Initializes a new instance of the ExtCursor class. [for design time only]. |
| ExtCursor Constructor(Bitmap,Bitmap,Point) | Initializes a new instance of the ExtCursor class from the specified bitmap image and mask. |
| ExtCursor Constructor(Bitmap,Point) | Initializes a new instance of the ExtCursor class from the specified bitmap image. (The transparent color is taken as the color of the bottom-left pixel) |
| ExtCursor Constructor(Bitmap,Point,Boolean) | Initializes a new instance of the ExtCursor class from the specified bitmap image. (Optionally automatically drawing the cross-hairs for the cursor) (The transparent color is taken as the color of the bottom-left pixel) |
| ExtCursor Constructor(Bitmap,Color,Point) | Initializes a new instance of the ExtCursor class from the specified bitmap image. |
| ExtCursor Constructor(Bitmap,Color,Point,Boolean) | Initializes a new instance of the ExtCursor class from the specified bitmap image. (Optionally automatically drawing the cross-hairs for the cursor) |
| ExtCursor Constructor(ImageList,Int32,Point) | Initializes a new instance of the ExtCursor class from the specified image in an ImageList. |
| ExtCursor Constructor(ImageList,Int32,Point,Boolean) | Initializes a new instance of the ExtCursor class from the specified image in an ImageList. (Optionally automatically drawing the cross-hairs for the cursor) |
| ExtCursor Constructor(String) | Initializes a new instance of the ExtCursor class from the specified file. |
| ExtCursor Constructor(String,Boolean) | Initializes a new instance of the ExtCursor class from the specified file. |
| ExtCursor Constructor(Byte[]) | Initializes a new instance of the ExtCursor class from the supplied byte data. |
| ExtCursor Constructor(Stream) | Initializes a new instance of the ExtCursor class from the supplied stream. |
| ExtCursor Constructor(Assembly,String,String) | Initializes a new instance of the ExtCursor class from a resource. |
| ExtCursor Constructor(Assembly,String,String,Boolean) | Initializes a new instance of the ExtCursor class from a resource. |
| ExtCursor Constructor(String,Boolean,Size) | Initializes a new instance of the ExtCursor class from the specified file. |
| ExtCursor Constructor(String,Boolean,Size,Boolean) | Initializes a new instance of the ExtCursor class from the specified file. |
| ExtCursor Constructor(Byte[],Boolean,Size) | Initializes a new instance of the ExtCursor class from the supplied byte data. |
| ExtCursor Constructor(Stream,Boolean,Size) | Initializes a new instance of the ExtCursor class from the supplied stream. |
| ExtCursor Constructor(Assembly,String,String,Boolean,Size) | Initializes a new instance of the ExtCursor class from a resource. |
| ExtCursor Constructor(Assembly,String,String,Boolean,Size,Boolean) | Initializes a new instance of the ExtCursor class from a resource. |
