ExtCursor Constructor(Assembly,String,String,Boolean,Size,Boolean)
Initializes a new instance of the ExtCursor class from a resource.
- pResourceAssembly
- The assembly containing the resource.
- pResXName
- The name of the compiled resource file, e.g. "MyApp.Properties.Resources".
- pResourceName
- The name of the resource.
- pDefaultSize
- Whether the default system metric cursor size should be used.
- pPreferredSize
- The preferred size of the cursor to load.
- pShareable
- Whether the cursor handle is to be shared.
