ExtCursor Constructor(Stream,Boolean,Size)
Initializes a new instance of the ExtCursor class from the supplied stream.
public ExtCursor( Stream pCursorStream, bool pDefaultSize, Size pPreferredSize )
public: ExtCursor( Stream^ pCursorStream, bool pDefaultSize, Size pPreferredSize )
- pCursorStream
- The stream to load the cursor from.
- pDefaultSize
- Whether the default system metric cursor size should be used.
- pPreferredSize
- The preferred size of the cursor to load.
