The byte data to load the cursor from.
Whether the default system metric cursor size should be used.
The preferred size of the cursor to load.
ExtCursor Constructor(Byte[],Boolean,Size)
Initializes a new instance of the ExtCursor class from the supplied byte data.
pCursorData
pDefaultSize
pPreferredSize
