Aveva.ApplicationFramework.Presentation Namespace (Aveva.ApplicationFramework.Presentation)
Classes
| Class | Description | |
![]() | AnimationControl | Animated image control Animated Image Control |
![]() | ApplicationMenuBar | Class to represent the ApplicationMenu Ribbon element |
![]() | ButtonTool | Represents a ButtonTool. |
![]() | CancelClosingEventArgs | Provides data for a cancelable event. |
![]() | ComboBoxTool | Represents a ComboBoxTool. |
![]() | Command | Abstract base class which an application must inherit from to create a Command object. |
![]() | CommandBar | Class to represent a CommandBar. |
![]() | CommandBarEventArgs | Provides data for the CommandBarAdded and CommandBarRemoved events. |
![]() | CommandBarManager | Class representing a CommandBarManager. |
![]() | CommandBarMenuTool | Special tool which displays a menu of current CommandBars. |
![]() | CommandBarsCollection | Class to represent a CommandBarCollection. |
![]() | CommandContextCollection | |
![]() | CommandContextEventArgs | Store arguments for Command Context |
![]() | CommandExecutor | Abstract base class which an application must inherit from to create a CommandExecutor object. |
![]() | CommandList | An ArrayList use for the list property of Command objects which supports an IsModified property. |
![]() | CommandManager | Class representing a CommandManager. |
![]() | CommandTypesCollection | Class that represents a CommandCollection. |
![]() | ContainerTool | A tool that contains a Control. |
![]() | DockedWindow | Class to represent a DockedWindow. |
![]() | DragDropDirector | A class to help direct drag-drop events. |
![]() | DropTarget | A class to represent a DragDropTarget. |
![]() | DropTargetEventArgs | A class to provide information to for drop-drop events. |
![]() | EventAggregator | EventAggregator is a container for events that allows decoupling of publishers and subscribers so they can evolve independently. |
![]() | EventManager | Manager for events. |
![]() | FontListTool | Represents a FontListTool. |
![]() | Gallery | Gallery |
![]() | GalleryToolItem | Class to represent a GalleryToolItem. |
![]() | GalleryToolItemCollection | A collection of gallery tool items. |
![]() | GalleryToolItemEventArgs | Provides data for events on GalleryTool items |
![]() | GenericMessage | A generic message that takes object as param to pass around. |
![]() | HideMessageBoxTypeHelper | A helper class to check if a message box type if set based on the icon. |
![]() | HtmlHelp | A class to control Html Help viewer. |
![]() | IconInfo | Icon info as extracted from Resource File |
![]() | IconLoader | Icon Loader |
![]() | LabelTool | Class to represent a static Label. |
![]() | ListTool | Represents a ListTool. |
![]() | MdiWindow | Represents an MDI style window or dialog box. |
![]() | MdiWindowListTool | Special tool which displays a list of current MDI Windows. |
![]() | MenuTool | Represents a MenuTool. |
![]() | MessageBoxButtonsExtensions | MessageBoxButtons extensions. |
![]() | MessageBoxEx | Displays a message box that can contain text, buttons, and symbols that inform and instruct the user. |
![]() | PanelWindow | Class to represent a PanelWindow. |
![]() | PopupColorPickerTool | Represents a PopupColorPicker. |
![]() | PopupContainerTool | Represents a Popup Container Tool. |
![]() | PopupGalleryTool | Represents a MenuTool. |
![]() | ProgressBar | Class representing a ProgressBar. |
![]() | ProgressBarOptions | Options for controlling progress bar behaviour and appearance |
![]() | PromptsWindow | Class representing the Prompts Window. |
![]() | ResourceManager | Provides convenient access to culture-specific resources at runtime. |
![]() | ResourceSet | Represent a set of culture-specific resource files. |
![]() | RibbonBar | Class to represent the RibbonBar |
![]() | RibbonContextualTabGroup | Class to represent a Ribbon RibbonContextualTabGroup contextual tab set. |
![]() | RibbonContextualTabGroupEventArgs | Provides data for the RibbonTabGroupAdded and RibbonContextualTabGroupRemoved events. |
![]() | RibbonContextualTabGroupsCollection | Class to represent a RibbonContextualTabGroupsCollection. |
![]() | RibbonTab | Class to represent a RibbonTab. |
![]() | RibbonTabEventArgs | Provides data for the RibbonTabAdded and RibbonTabRemoved events. |
![]() | RibbonTabGroup | Class to represent a Ribbon RibbonTab Group. |
![]() | RibbonTabGroupEventArgs | Provides data for the RibbonTabGroupAdded and RibbonTabGroupRemoved events. |
![]() | RibbonTabGroupsCollection | Class to represent a RibbonTabGroupCollection. |
![]() | RibbonTabsCollection | Class to represent a RibbonTabCollection. |
![]() | RootToolsCollection | Class representing a RootToolsCollection. |
![]() | SplashScreen | Provides an application SplashScreen. |
![]() | StateButtonTool | Represents a StateButtonTool. |
![]() | StatusBar | Represents a Windows style status bar control. |
![]() | StatusBarPanelsCollection | Represents a collection of status bar panels. |
![]() | StatusBarTextPanel | Represents a StatusBarTextPanel. |
![]() | TabbedWindow | Class to represent a TabbedWindow. The tabbed window resides on the left or right side of the 3D view |
![]() | TaskBar | Class representing a Microsoft Office style "TaskPane" type toolbar. |
![]() | TaskManager | Manager for tasks. |
![]() | TaskPaneTool | Class used to represent a single item in a TaskPane. |
![]() | TextBoxTool | Represents a TextBoxTool. |
![]() | ThemeColours | Class which provides a number of Theme colours |
![]() | Tool | Represents a Tool. |
![]() | ToolEventArgs | Provides information for Tool events. |
![]() | ToolsCollection | Class representing a ToolsCollection. |
![]() | User32.HWND | Window handles (HWND) used for hWndInsertAfter. |
![]() | ValueList | Class representing a ValueList, which is a collection of ValueListItem objects. It is typical assigned to a ComboBoxTool as the list of options displayed as the dropdown list. |
![]() | ValueListItem | Class representing a ValueListItem, which can be a member of ValueList. |
![]() | Wheel | Wheel |
![]() | WindowEventArgs | Provides data for the WindowAdded event. |
![]() | WindowManager | Provides access to window related facilities. |
![]() | WindowsCollection | Provides access to a collection of application windows. |
![]() | Wizard | Represents an extentable wizard control with basic page navigation functionality. |
![]() | Wizard.AfterSwitchPagesEventArgs | Provides data for the AfterSwitchPages event of the Wizard control. |
![]() | Wizard.BeforeSwitchPagesEventArgs | Provides data for the BeforeSwitchPages event of the Wizard control. |
![]() | WizardPage | Represents a wizard page control with basic layout functionality. |
![]() | WizardPagesCollection | Represents a collection of wizard pages. |
Interfaces
| Interface | Description | |
![]() | IApplicationInfo | Interface use to supply application information to the framework |
![]() | ICancelIndicator | Interface for elements with cancel functionality |
![]() | ICheckedTool | Tools that have a checked state |
![]() | ICommandBarManager | Interface for CommandBarManager. |
![]() | ICommandManager | Interface for CommandManager |
![]() | IDragDropDirector | Interface for DragDropDirector |
![]() | IGallery | Gallery |
![]() | IHtmlHelp | Interface for HtmlHelp. |
![]() | IInterruptible | Interface for interruptible classes. |
![]() | IMessageEx | Interface implemented by plugged message output |
![]() | IPopupGalleryToolCommand | |
![]() | IProgressIndicator | Progress Indication API |
![]() | IResourceManager | Provides convenient access to culture-specific resources at runtime. |
![]() | IStatusBarPanel | Interface supported by Statusbar panels. |
![]() | ITool | Interface supported by all Tool classes. |
![]() | IToolCollection | Interface for tools which have a tools collection. |
![]() | ITools | Interface for tools which have a tools collection. |
![]() | IUicManager | Manager for UIC configurations |
![]() | IUICustomization | Interface for UIC storage class |
![]() | IWheel | Wheel |
![]() | IWindow | Interface supported by supported window types(MDI, Docked). |
![]() | IWindowManager | Interface for Window Manager. |
![]() | IZoom | A control that implements zooming |
Structures
| Structure | Description | |
![]() | IconLoader.ICONINFO | Icon Info structure |
![]() | User32.FLASHWINFO | A flashwinfo. |
![]() | User32.RECT | A rectangle. |
Delegates
| Delegate | Description | |
![]() | CommandBarEventHandler | Represents the method that will handle CommandBar related events. |
![]() | CommandContextEventHandler | Represents the method that will handle command context related events. |
![]() | CommandEventHandler | Represents the method that will handle command related events. |
![]() | DropTargetEventHandler | Represents the method that will handle DropTarget related events. |
![]() | GalleryToolItemEventHandler | Represents the method that will handle CommandBar related events. |
![]() | RibbonContextualTabGroupEventHandler | Represents the method that will handle RibbonContextualTabGroup related events. |
![]() | RibbonTabEventHandler | Represents the method that will handle RibbonTab related events. |
![]() | RibbonTabGroupEventHandler | Represents the method that will handle RibbonTabGroup related events. |
![]() | ToolEventHandler | Represents the method that will handle Tool related events. |
![]() | WindowEventHandler | Represents the method that will handle Window related events. |
![]() | Wizard.AfterSwitchPagesEventHandler | Represents the method that will handle the AfterSwitchPages event of the Wizard control. |
![]() | Wizard.BeforeSwitchPagesEventHandler | Represents the method that will handle the BeforeSwitchPages event of the Wizard control. |
Enumerations
| Enumeration | Description | |
![]() | CommandBarStyle | Enumerator used to specify the look and feel of the toolbar |
![]() | CommandState | Enumeration for various states of a command. This enumeration can be treated as a bit field; that is, a set of flags. Bit fields can be combined using a bitwise OR operation. |
![]() | ControlResizeSide | Flags to define resizing side(s) |
![]() | CustomizationType | Enumeration of menu and commandbar customisation options |
![]() | DockedPosition | Enumerator used to specify the location of a toolbar or window docking area. |
![]() | DockGroupStyle | Enumeration of styles for group docked windows. |
![]() | DropDownArrowStyle | Enumerator used to specify the style used to draw a popup tool's dropdown arrow. Also determines which part of the tool should be clicked to drop down the tool. |
![]() | HideMessageBoxType | Flags to set type of Message boxes to hide based on the icon Since some Icons are shared, the number of types to hide is lower than the MessageBoxeIcon enum. |
![]() | InsertPosition | Position to insert new element |
![]() | LayoutDirection | Enumeration used to define how the tools within the group are arranged. |
![]() | MessageBeepType | Values that represent message beep types. |
![]() | MessageBoxExButtons | Specifies constants defining which buttons to display on a MessageBoxEx. |
![]() | Msgs | Windows Event Messages sent to the WindowProc. |
![]() | NavigationButtonStyle | Enumeration used to indicate how the navigation buttons are used to navigate the items in a TaskBar |
![]() | PanelSizingMode | Enumeration of the statusbar panel sizing options. |
![]() | PanelStyle | Panel appearance |
![]() | PopupAnimations | Types of animation of the pop-up window. |
![]() | PopupStyle | Enumerator used to specify the style of popup menus. |
![]() | PromptWindowStyle | Prompt Window styles |
![]() | StandardImage | Enumeration of standard images |
![]() | StateButtonCommandBarDisplayStyle | Enumerator used to specify the display style of a StateButtonTool when it is displayed on a CommandBar or Ribbon. |
![]() | StateButtonMenuDisplayStyle | Enumerator used to specify the display style of a StateButtonTool's image when the tool appears on a menu. |
![]() | TextHorizontalAlignment | Enumerator used to specify horizontal text alignment. |
![]() | TextPlacement | Enumerator used to specify the text placement of a gallery tool item. |
![]() | ToolDisplayStyle | Enumerator used to specify the display style of a tool. |
![]() | UpdateOptions | Enumerations for the options for automatically updating the state of a MenuTool following state changes to an child StateButtonTool or ButtonTool. This enumeration can be treated as a bit field; that is, a set of flags. Bit fields can be combined using a bitwise OR operation. |
![]() | User32.GetWindow_Cmd | Values that represent get window commands. |
![]() | User32.SetWindowPosFlags | A bit-field of flags for specifying set window position options. |
![]() | User32.ShowWindowCommands | Values that represent show window commands. |
![]() | User32.WindowLongFlags | Values that represent window long flags. |
![]() | User32.WindowStyles | Window Styles. The following styles can be specified wherever a window style is required. After the control has been created, these styles cannot be modified, except as noted. |
![]() | User32.WindowStylesEx | A bit-field of flags for specifying window styles exes. |
![]() | ValueListDisplayStyle | Enumeration for specifying what property of a value list item will be displayed in each item of the DropDown list |
![]() | ValueListSortStyle | Enumeration for specifying how value list items will be sorted when displaying value list items in a drop down list |
![]() | WizardPageStyle | Represents possible styles of a wizard page. |
