PopupAnimations Enumeration
Types of animation of the pop-up window.
[Flags()] public enum PopupAnimations : System.Enum
[Flags()] public enum class PopupAnimations : public System.Enum
Members
| Member | Description |
| Blend | Uses a fade effect. |
| BottomToTop | Animates the window from bottom to top. This flag can be used with roll or slide animation. |
| Center | Makes the window appear to collapse inward if it is hiding or expand outward if the window is showing. |
| LeftToRight | Animates the window from left to right. This flag can be used with roll or slide animation. |
| None | Uses no animation. |
| RightToLeft | Animates the window from right to left. This flag can be used with roll or slide animation. |
| Roll | Uses a roll animation. |
| Slide | Uses a slide animation. |
| SystemDefault | Uses a default animation. |
| TopToBottom | Animates the window from top to bottom. This flag can be used with roll or slide animation. |
Inheritance Hierarchy
System.Object
System.ValueType
System.Enum
Aveva.ApplicationFramework.Presentation.PopupAnimations
