CommandState Enumeration
Enumeration for various states of a command. This enumeration can be treated as a bit field; that is, a set of flags. Bit fields can be combined using a bitwise OR operation.
[Flags()] public enum CommandState : System.Enum
[Flags()] public enum class CommandState : public System.Enum
Members
| Member | Description |
| Checked | Command is in checked state. |
| Disabled | Command is disabled. |
| Enabled | Command is enabled. |
| Hidden | Command is hidden. |
| Unchecked | Command is in unchecked state. |
Inheritance Hierarchy
System.Object
System.ValueType
System.Enum
Aveva.ApplicationFramework.Presentation.CommandState
