ValueList Class Methods
For a list of all members of this type, see ValueList members.
![]() | Add | Overloaded. Create and add a new ValueListItem object to the ValueList. Note that the ValueListItem created will contain the given DisplayText and a default DataValue with value (object)DisplayText. |
![]() | Clear | Remove all ValueListItems from the ValueList. |
![]() | GetEnumerator | Returns an enumerator that can iterate through the Collection. |
![]() | Insert | Overloaded. Create and insert a new ValueListItem object into the ValueList. Note that the ValueListItem created will contain the given DisplayText and a default DataValue with value (object)DisplayText. |
![]() | Remove | Overloaded. Remove the ValueListItem with the specified DisplayText from the ValueList. |
