Insert Method (ValueList)
Create and insert a new ValueListItem object into the ValueList.
Note that the ValueListItem created will contain the given DisplayText
and a default DataValue with value (object)DisplayText.
Overload List
| Overload | Description |
| Insert(String,Int32) | Create and insert a new ValueListItem object into the ValueList. Note that the ValueListItem created will contain the given DisplayText and a default DataValue with value (object)DisplayText. |
| Insert(String,Object,Int32) | Create and insert a new ValueListItem object into the ValueList. |
| Insert(String,Object,Image,Int32) | Create and insert a new ValueListItem object into the ValueList. |
