ValueList Class Members
The following tables list the members exposed by ValueList.
![]() | DisplayStyle | Set the DisplayStyle for the ValueList. ValueListDisplayStyle enumeration specifies what properties of ValueListItems will be displayed. |
![]() | Item | Overloaded. Indexer to get the ValuListItem at the given position index from the ValueList. |
![]() | SortStyle | Set the SortStyle for the ValueList. ValueListSortStyle enumeration specifies how the ValueListItems will be sorted for display. |
![]() | Add | Overloaded. Create and add a new ValueListItem object to the ValueList. Note that the ValueListItem created will contain the given DisplayText and a default DataValue with value (object)DisplayText. |
![]() | Clear | Remove all ValueListItems from the ValueList. |
![]() | GetEnumerator | Returns an enumerator that can iterate through the Collection. |
![]() | Insert | Overloaded. Create and insert a new ValueListItem object into the ValueList. Note that the ValueListItem created will contain the given DisplayText and a default DataValue with value (object)DisplayText. |
![]() | Remove | Overloaded. Remove the ValueListItem with the specified DisplayText from the ValueList. |
