GetImage Method (IResourceManager)
Gets a resource Image.
Overload List
| Overload | Description |
| GetImage(String) | Gets a resource Image. |
| GetImage(String,Int32) | Gets a resource Image. |
| GetImage(String,String) | Gets a resource Image from the named resource set. |
| GetImage(String,String,Int32) | Gets a resource Image from the named resource set. |
| GetImage(String,String,String) | Gets a resource Image from the named resource set. Uses defaultResourceId if resourceID is not found |
| GetImage(String,String,String,Int32) | Gets a resource Image from the named resource set. Uses defaultResourceId if resourceID is not found |
