GetImage(String,String,String) Method
Gets a resource Image from the named resource set. Uses defaultResourceId if resourceID is not found
Image GetImage( string resourceId, string resourceSetName, string defaultResourceId )
Image^ GetImage( String^ resourceId, String^ resourceSetName, String^ defaultResourceId )
- resourceId
- Resource identifier for the required Image
- resourceSetName
- Name of resource set to look in
- defaultResourceId
- Name of default resource id to use if given resource id is not found
