GetImage(String,String,String,Int32) Method
Gets a resource Image from the named resource set. Uses defaultResourceId if resourceID is not found
- resourceId
- Resource identifier for the required Image
- resourceSetName
- Name of resource set to look in
- defaultResourceId
- Name of default resource id to use if given resource id is not found
- size
- Size of image to return if extracted from icon file
