Global WCF Configuration Guide
Certificate Based Authentication : Configure the WCF HTTP Endpoint : Bind Certificate With Windows XP or Windows Server 2003
At the -h parameter, paste the value copied to the clipboard in the previous steps making sure that spaces are removed from the hexadecimal string.
This command binds the certificate with the thumbprint indicated with the -h flag to the port indicated by the -i flag. The port is specified as the IP address of the computer followed by the port. The IP address 0.0.0.0 specifies the local computer.
