Global WCF
Configuration Guide
Certificate Based Authentication
It is possible to configure Global WCF to authenticate Global data exchanges against a valid SSL certificate.
The following section describes how to prepare and install a certificate ready for use by Global WCF.
If the user does not intend to use an SSL certificate then skip to section
WCF Configuration Files
