Global WCF Configuration Guide
Certificate Based Authentication : Configure the WCF HTTP Endpoint : Obtain Certificate Thumb Print
Navigate to Certificates (Local Computer) > Personal > Certificates and select <your certificate name>. In the following example the certificate is listed as 'tempCert'.
Click the Details Tab.
Select the Thumbprint option from the list.
