Multi-Discipline Supports
Using the MDS Application
Special Supports
: Create a Special SCTN
The Copy Section icon
allows the user to copy
any
SCTN member from the current special support.
This is not restricted to the Copy Project Special option.
To create a special SCTN:
1.
Click on the icon and the Identify Section to Copy prompt is displayed.
2.
Select a SCTN member of the current special support.
A message appears to indicate that the identified section has been copied and moved up 300mm. The section name becomes
support name-Vnn
The user can copy as many SCTNs as required and if necessary use the standard Beams and Columns application to complete the design of the special support.
