Multi-Discipline Supports
Administrator Guide
MDS Ancillary Defaults Form
Standard Tab
: Elevation Restriction
Specifies the elevation (height) at which an ancillary can be created at and above. For example, setting a value of 5000 means the ancillary can be created at any elevation at 5000 mm and ABOVE, but NOT below 5000mm.
The default setting is *, meaning there is no restriction on the elevation at which the ancillary can be created.
