MDS lighting support types are described in section
MDS Lighting Support Defaults.
MDS Structural Framework Support types are described in section
MDS Structure Defaults Form.
The information on the form is grouped into two sections. Design detail in the Standard section applies to all signs of the component. The
Bore Specific section contains data associated with the specified size (bore) of component.
The Apply button should be used before selecting another standard, otherwise any changes will be lost.
