Multi-Discipline Supports Administrator Guide
MDS Ancillary Defaults Form
The MDS Ancillary Defaults form contains the design parameter definitions for all the ancillary support components that can be modelled using design parameters in the MDS catalogue. It allows the administrator to define the physical dimensions of all the ancillaries to match a given vendor. The supplied parameters are generally based on, but not exclusively:
Changes made are only applied to the database when the Apply button is pressed. The Dismiss button removes the form. If changes have been made, but not applied, a window is displayed asking if the changes are to be applied before exiting.
