Multi-Discipline Supports Administrator Guide
MDS Ancillary Defaults Form : Standard Tab : Standard Replacement Name
This is the client’s replacement support name used on all forms in the MDS application when referring to the support type defined by the Support Standard. It is also output in place of the Support Standard name on MDS Automatic Drawing Production drawings. The name can be modified by editing the text in this field. All characters in the replacement name MUST be alpha/numeric only.
