DRAW Reference Manual
Section Planes : Creating and Using Planes : Stepped Plane (SPLA)
(The pictures in the left half of Figure 5:7.: Use of the Stepped Plane (SPLA) 7 illustrate the use of the SKETCH PLANE facility. Refer to Plane Querying for further information.)
is output. If the plane is not satisfactory then the message will indicate what the problem is. Generally, an SPLA will be incorrect if parts of the plane overlap even if extruded to infinity at the ends; Figure 5:8.: Plane Errors illustrates this situation.
Figure 5:8.
