DRAW Reference Manual
Dimensioning
Angular Dimensions
: Detail Attributes of Angular Dimensions
Angular Dimensions have the same TRUN and DMSP attributes as Linear Dimensions. Dimension arc and projection line (dimension radius line) text is set and positioned in the same way as for linear dimensions. Projection line gaps are also handled in the same way.
At ADIMs the default setting of attribute DMTX is ’#DIM~0’. This produces a degree symbol after the angle value, which is output to one decimal place. (Refer to
Intelligent Text
for further information about ‘hash codes’, e.g. #DIM.)
The
DTANGLE
(Dimension text angle) attribute is available for Angular Dimensions and their Dimension Points. However, the settings are restricted to the following:
DTANG HORIZ
DTANG VERT
DTANG STAN
DTANG DEF
The meanings of these settings are similar to those for Linear Dimensions (refer to
Detail Attributes of Linear Dimensions
for further information).
