DRAW Reference Manual
Dimensioning : Linear Dimensions : Detail Attributes of Linear Dimensions
Example:
Dimension line text (DMTX) is set by a command of the form:
DMTX text
Example:
DMTX ’ACCESS SPACE’
(refer to Figure 11:13.: Dimension Line Text, left hand, for further information)
DMTX ’ACCESS SPACE #/#DIM’
(refer to Figure 11:13.: Dimension Line Text, right hand, for further information)
Figure 11:13.
#DIM in the example above takes the value of the dimension. #DIM is a simple case of intelligent text. Refer to Intelligent Text for further information. Note that in the case of non-truncated parallel dimensions, the dimension line spacing will automatically be adjusted to accommodate two or more lines of text if these are input. Dimension line text may be set at Dimension Point or Dimension level, although in the latter case the text input will attached to all the dimension lines involved. Associated commands are:
- (at Dimension Point level): set dimension text to that of owning Dimension
Dimension text angle can be controlled using the DTANGLE attribute. This is available both at dimension and dimension point level. Possible settings are:
Projection line text (PLTX) is set and manipulated in a similar way. For example, the commands:
Figure 11:15.
Example:
Refer to Figure 11:16.: Projection Line Text Offset for an example of changing the projection line text offset.
Projection text angle can be controlled using the PTANGLE attribute. This is available both at dimension and dimension point level. Possible settings are:
The HORIZONTAL and VERTICAL settings cause the projection line text to be drawn respectively horizontally or vertically in the VIEW. In these cases, the projection line is not extended automatically to underline the text but only overshoots the dimension line by the distance specified by the OSHT attribute.
Dimension line and projection line text can be edited through use of the EDTEXT command. In the following examples, the target string is ‘ACCESS DPACE’, = ‘ACCESS SPACE’ mistyped:
- Change dimension line text to ‘ACCESS SPACE’
- Change projection line text to 'ACCESS SPACE
Dimension line terminators are arrowheads by default, but may be obliques, dots, or absent altogether - Refer to Figure 11:19.: Dimension Line Terminators for further information.
The first terminator of a truncated dimension (Refer to Figure 11:11.: Truncated Parallel Dimension for further information) can be set independently using the FTER attribute. The first terminator will be drawn 25% larger than the remainder.
DLSTYLE integer/line_pattern,
PLSTYLE integer/line_pattern
DLCOLOUR integer/colour_name
PLCOLOUR integer/colour_name
Gaps in projection lines are most easily defined using the cursor, with either the start and end points or a mid point and a length being specified. Examples of the relevant commands are:
