DRAW Reference Manual
Dimensioning : Linear Dimensions : Multi-valued Dimensions
The preceding examples have dealt with single-valued dimensions; where more than two Dimension Points are involved, the Dimension is said to be multi-valued. Two classes of multi-valued Dimensions exist, namely chained and parallel. An example of a chained Dimension is shown in Figure 11:5.: Chained Linear Dimension.
Such a dimension (which is still represented by a single LDIM element) is created by repeating the TO part of the FROM . . . TO command line, moving the cursor crosshairs to each Dimension Point in turn. The example shown in Figure 11:4.: Before/After’ Linear Dimensions on a Single Element would have been created by a command sequence such as:
A Dimension Point may be constructed using DRAW’s point construction facilities (refer to Point and Line Construction for further information). For example:
The effect of the INSERT command is to create a new Dimension Point of the appropriate type at the last position in the owning LDIM's member list. INSERT can be used at Dimension Point or LDIM level.
A parallel Dimension can be produced simply by setting the LCHA attribute of an LDIM as appropriate:
