TextBoxTool Class Properties
For a list of all members of this type, see TextBoxTool members.
![]() | DisplayText | Gets or sets the text displayed in the tool. |
![]() | Editable | Gets or sets whether the TextBoxTool is editable |
![]() | EditorWidth | Gets or sets the width of the edit area within the tool. |
![]() | MaxLength | Gets or sets the maximum allowable length of the text that can be entered in the TextBoxTool |
![]() | PasswordChar | Gets or sets a value indicating how the characters typed by a user are displayed. |
![]() | Width | Gets or sets the width of the tool. |
