TextBoxTool Class Members
The following tables list the members exposed by TextBoxTool.
Protected Fields
![]() | DisplayText | Gets or sets the text displayed in the tool. |
![]() | Editable | Gets or sets whether the TextBoxTool is editable |
![]() | EditorWidth | Gets or sets the width of the edit area within the tool. |
![]() | MaxLength | Gets or sets the maximum allowable length of the text that can be entered in the TextBoxTool |
![]() | PasswordChar | Gets or sets a value indicating how the characters typed by a user are displayed. |
![]() | Width | Gets or sets the width of the tool. |
Protected Methods
Public Events
![]() | ToolClick | Occurs when Enter key is pressed while text field has focus. |
![]() | ToolValueChanged | Occurs when the value of the TextBoxTool changes |
