StatusBar Class Properties
For a list of all members of this type, see StatusBar members.
![]() | Delay | Delay before showing progress (ms) |
![]() | Enabled | Gets or sets the enabled state of the status-bar |
![]() | MarqueeBounce | Marquee setting, not implemented |
![]() | MarqueeColor | Marquee setting, not implemented |
![]() | MarqueeSpeed | Marquee setting, not implemented |
![]() | Panels | Gets the collection of application defined status-bar panels. |
![]() | Progress | Gets or sets the progress bar value [0-100]. |
![]() | ProgressMaximum | Upper limit for progress indicator |
![]() | ProgressMinimum | Lower limit for progress indicator |
![]() | ProgressShowLabel | Flag for progress label overlaying the status-bar |
![]() | ProgressText | Gets or Sets the text that is displayed with the progress bar (left). |
![]() | ProgressTextAdditional | Gets or Sets the text that is displayed with the progress bar (right). |
![]() | ProgressTextMaxSize | Clip progress text to this size, set to zero for no clipping |
![]() | ProgressTitle | Gets or Sets the text that is displayed as a title of the progress bar. |
![]() | ShowZoom | Gets or sets whether the ZoomBar is showing |
![]() | Text | Gets or sets the text to display in the status-bar text pane. |
![]() | TextMaxSize | Clip text to this size, set to zero for no clipping |
![]() | TextTooltipMaxSize | Clip text tooltip to this size, set to zero for no clipping |
![]() | UseMarqueeStyle | Marquee style, not implemented |
![]() | Visible | Gets or sets the visibility of the status-bar. |
![]() | ZoomLargeChange | Zoom-bar Large Change |
![]() | ZoomMaxValue | ZoomBar Maximum Value |
![]() | ZoomMidpointValue | ZoomBar Midpoint Value, set to null for automatically determined value |
![]() | ZoomMinValue | ZoomBar Minimum Value |
![]() | ZoomSmallChange | ZoomBar Small Change |
![]() | ZoomValue | ZoomBar current value |
