The string to test for containment.
The command.
true to from XML.
AddRibbonTab(String,Command,Boolean) Method
Create and add to the RibbonTabCollection a new RibbonTab with given Key and command.
public abstract RibbonTab AddRibbonTab(
   string key,
   Command command,
   bool fromXml
abstract RibbonTab^ AddRibbonTab(
   String^ key,
   Command^ command,
   bool fromXml
key
command
The command.
fromXml
true to from XML.
A RibbonTab.
