RibbonTabsCollection Class Members
The following tables list the members exposed by RibbonTabsCollection.
![]() | Item | Indexer to get the RibbonTab with given Key from the RibbonTabCollection. |
![]() | SelectedRibbonTab | The Ribbon Tab to be Selected |
![]() | AddRibbonTab | Overloaded. Create and add to the RibbonTabCollection a new RibbonTab with given Key. |
![]() | Clear | Remove all RibbonTabs from the RibbonTabCollection. |
![]() | Contains | Determine if the RibbonTab with the specified Key exists in the RibbonTabCollection. |
![]() | GetEnumerator | Returns an enumerator that can iterate through the RibbonTabCollection. |
![]() | MoveRibbonTab | Move the RibbonTab with given key to the given position (index) in the RibbonTabCollection. |
![]() | RemoveRibbonTab | Overloaded. Remove the RibbonTab with given Key from the RibbonTabCollection. |
Public Events
![]() | RibbonTabAdded | Occurs after a RibbonTab has been added to the RibbonTabCollection. |
![]() | RibbonTabRemoved | Occurs after a RibbonTab has been removed from the RibbonTabCollection. |
