ProgressBarOptions Class Properties
For a list of all members of this type, see ProgressBarOptions members.
![]() | Block | Dialog will also block |
![]() | BlockMainUI | Block interaction with main UI whilst progress bar is displayed |
![]() | CancelEnabled | Cancel button enabled |
![]() | CancelText | Cancel button text |
![]() | CancelVisible | Cancel button visible |
![]() | MarqueeBounce | When set activity indicator will bounce from side to side |
![]() | MarqueeColor | Activity indicator color |
![]() | MarqueeSpeed | Activity indicator speed |
![]() | Maximum | Upper limit for progress range |
![]() | Minimum | Lower limit for progress range |
![]() | ProgressText | Text to show indicating current progress (left) |
![]() | ProgressTextAdditional | Text to show indicating current progress (right) |
![]() | ShowDialog | When true uses modal dialog, otherwise use status bar progress |
![]() | ShowLabel | Show percentage text as label over progress bar |
![]() | Title | Title for progress bar |
![]() | TopMost | When set dialog will be forced as topmost window set to null for default behaviour (only true when blocking) |
![]() | UseMarqueeStyle | When set will act as activity indicator |
