ComboBoxTool Class Properties
For a list of all members of this type, see ComboBoxTool members.
![]() | AutoComplete | Gets or sets whether the edit portion is automatically updated to match an item in the list as new characters are typed. |
![]() | DisplayText | Gets or sets the text displayed in the tool. |
![]() | Editable | Gets or sets whether the text portion of the ComboBoxTool is editable. |
![]() | MaxLength | Gets or sets the maximum allowable length of the text that can be entered in the ComboBoxTool. |
![]() | PasswordChar | Gets or sets a value indicating how the characters typed by a user are displayed. |
![]() | RealSizeImagesInPreview | Flag to control image scaling in preview |
![]() | SelectedIndex | Gets or sets the zero-based index of the selected item in the ValueList. |
![]() | SelectedValue | Returns the object behind the selected ValueList item. |
![]() | ValueList | Gets the ValueList object associated with the ComboBoxTool. |
![]() | Width | Gets or sets the width of the tool. |
