ComboBoxTool Class Members
The following tables list the members exposed by ComboBoxTool.
Protected Fields
![]() | AutoComplete | Gets or sets whether the edit portion is automatically updated to match an item in the list as new characters are typed. |
![]() | DisplayText | Gets or sets the text displayed in the tool. |
![]() | Editable | Gets or sets whether the text portion of the ComboBoxTool is editable. |
![]() | MaxLength | Gets or sets the maximum allowable length of the text that can be entered in the ComboBoxTool. |
![]() | PasswordChar | Gets or sets a value indicating how the characters typed by a user are displayed. |
![]() | RealSizeImagesInPreview | Flag to control image scaling in preview |
![]() | SelectedIndex | Gets or sets the zero-based index of the selected item in the ValueList. |
![]() | SelectedValue | Returns the object behind the selected ValueList item. |
![]() | ValueList | Gets the ValueList object associated with the ComboBoxTool. |
![]() | Width | Gets or sets the width of the tool. |
Protected Methods
Public Events
![]() | AfterCloseup | Occurs after the popup part of the tool is closed. |
![]() | AfterPopup | Occurs after the popup part of the tool is displayed. |
![]() | BeforePopup | Occurs before the popup part of the tool is displayed. |
![]() | ToolClick | Occurs when Enter key is pressed while display field has focus. |
![]() | ToolValueChanged | Occurs when the value of the tool changes. |
