IWindowManager Interface Properties
For a list of all members of this type, see IWindowManager members.
![]() | ActiveWindow | Gets or sets the current active window, either a docked one or an MDI one. |
![]() | AvailableLeftHandPosition | Get an appropriate position to place an information window on the left hand side of the main window. |
![]() | AvailableRightHandPosition | Get an appropriate position to place an information window on the right hand side of the main window. |
![]() | ClearCanvas | Get or set for Clear Canvas. |
![]() | CloseAllTabsExceptThisMenu | Get or set whether to use the "Close All Tabs Except This" menu. |
![]() | CommandBarManager | gets CommandBarManager associated with this WindowManager. |
![]() | CursorState | Hide/Show the cursor. |
![]() | DefaultFontName | Gets the application font name. |
![]() | Enabled | Get or set a property which controls the enabled state of all docked windows. |
![]() | ErrorTooltip | Gets Error Tooltip Window. |
![]() | FormTabContent | Get or set the tab content of forms. |
![]() | GraphicalViewTabsTop | Get or set the position of the graphical view tabs. |
![]() | hideMessageBoxes | Gets or sets the hide message boxes. |
![]() | IsApplicationClosing | Get whether or not the application is closing. |
![]() | IsApplicationOpening | Get whether or not the application is opening. |
![]() | MainForm | Gets the main application Form. |
![]() | Opacity | Get or set the opacity of forms. |
![]() | OverrideCursorState | Override cursor hide state. |
![]() | ProgressBar | Gets ProgressBar object. |
![]() | PromptsWindow | Gets Prompts Window. |
![]() | SlidingForms | Get or set whether Sliding Forms are to be used for the application. |
![]() | SlidingFormsLeftSplitterPosition | Get or set the position of the splitter (as a percentage) on the left sliding Form (0 at bottom, 100 at top) |
![]() | SlidingFormsRightSplitterPosition | Get or set the position of the splitter (as a percentage) on the right sliding Form (0 at bottom, 100 at top) |
![]() | SplashScreen | Gets the SplashScreen object. |
![]() | StatusBar | Gets the StatusBar object. |
![]() | StyleLibrary | Get or set the name of the Style Library to use for the application. |
![]() | TabbedMdi | Gets or sets whether MDI windows are displayed as tabbed windows. |
![]() | VisibleGraphicsRectangle | Get the visible graphics area. |
![]() | Windows | Gets the WindowCollection object. |
