Supports
Support Editor
Common Functions
: Rotate Hanger Component
Rotates an individual hanger ancillary.
The hanger name displays at the top of the
Rotate One Hanger Component
window.
Input a value in the
Angle
field to rotate the hanger. For example input
180
in the
Angle
field to rotate the hanger ancillary
180
degrees. The default rotation angle is 90 degrees.
Click
Apply
to rotate the hanger ancillary.
You are prompted to
Identify hanger component to rotate
Click to identify the hanger ancillary using a cursor pick in the 3D view. The hanger ancillary is rotated.
Click
Cancel
to close the
window.
