Depending on the selections made in the Support Editor window, you are presented with further windows prompting for input. After inputting information in these windows you are returned to the
Support Editor window, allowing the workflow to continue.
By default, the display of the Support Editor window is configured for the settings of the currently selected support type.
The Support Editor window allows you to create, position and refine the detailing for the support and the associated ancillaries. Only the options available for the selected support type are active.
The support name displays at the top of the Support Editor window. By default, the Supports application populates the
Name field. Refer to
Auto Name Defaults for further information. You can input a value in the field to modify the support name.
Click Apply to create the support and close the
Click Cancel to discard any inputs and close the
Support Editor window. A confirm window displays asking you to OK the deletion. Click
Yes to delete the item.
