Supports User Guide
Support Editor : Common Functions : Rotate Component
You are prompted to Identify ancillary to rotate
Input a value in the Angle field to rotate the ancillary. For example input 180 in the Angle field to rotate the Ancillary 180 degrees. The default rotation angle is 90 degrees.
Click Align to align the ancillary to a surface using a cursor pick in the 3D view.
You are prompted to Pick a surface to align with :
Click OK to rotate the ancillary or Cancel to discard any changes and close the Rotate window.
