Structural Design User Guide
Create Wall Fittings : Create Floor Fittings : Compound Fitting
In the model explorer or in the 3D view, select the wall where the fittings are to be positioned as the CE. On the WALLS AND FLOORS tab, from the Create group, select Compound Floor Fitting from the drop-down list to display the Floor Fittings window. By default, Create Compound is selected.
