From the model explorer or 3D view, select the floor/screed where the fittings are to be positioned as the CE. On the
WALLS AND FLOORS tab, from the
Create group, select
Floor Fitting from the drop-down list. The
Floor Fittings window is displayed.
The functionality available from the Floor Fittings window is identically to that available from
Wall Fittings (for more information on
Wall Fittings, refer to
Create Wall Fittings) with these exception:
From the Positioning pane of the
Floor Fittings window, select the reference datum from the available list.
The location of the fitting on the floor is set by the input of the X Position and
Y position. These two dimensions are measured from the origin of the owning wall indicated by the aid line in the graphic display.
Select Position fitting to display the
Positioning Control toolbar, the user is prompted to
‘Position Floor Fitting (Snap) Snap’ to position the fitting directly on the floor.
Click Apply to insert the floor fitting or click
Cancel to discard any information and close the
Floor Fittings window.
