DRAW User Guide
Add and Modify Drawing Objects : Determine Distances, Angles and Points : Measure Angle between two Points
To measure the angle between two points, on the Draw tab, in the Measure group, click Angle.
The user is prompted to Specify base point
Input values in the dimension fields and press Enter or click to identify the point to measure from.
The user is then prompted to Specify angle vertex or
Input values in the dimension fields and press Enter or click to identify the point to measure to.
Throughout the angle measuring process the user can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Base angle to specify the base angle vertex. Refer to Measure Angle between Two Points using a Base Angle for further information.
Input F at the prompt and press Enter to end the command.
Input B at the prompt and press Enter.
The user is then prompted to Specify the base angle vertex
Input values in the dimension fields and press Enter or click to identify the base angle vertex.
Input values in the dimension fields and press Enter or click to identify the vertex to measure from using the base angle.
