DRAW User Guide
Add and Modify Drawing Objects : Determine Distances, Angles and Points : Measure Distance between two Points
To measure the distance between two points, on the Draw tab, in the Measure group, click Distance.
The user is then prompted to Specify the first point
Input values in the dimension fields and press Enter or click to identify the point to measure from.
The user is then prompted to Specify the second point
Input values in the dimension fields and press Enter or click to identify the point to measure to.
Input F at the prompt and press Enter to end the command.
