Press the down arrow key and select Angle to set the chamfer angle. Refer to Set Chamfer Angle for further information.
Press the down arrow key and select Distance to set the chamfer distance. Refer to Set Chamfer Distance for further information.
Press the down arrow key and select mEthod to select the chamfer method. Refer to Select Chamfer Method for further information.
Press the down arrow key and select Multiple to chamfer multiple objects. Refer to Chamfer Objects for further information.
Press the down arrow key and select Select object to select an object and begin the chamfer process.
Press the down arrow key and select Trim to turn trimming on or off. Refer to Turn Trim On/Off for further information.
