Press the down arrow key and select Crossing to select objects using a selection box.
Press the down arrow key and select Delete to delete an object.
Press the down arrow key and select Edge to trim objects to extrapolated edges. Refer to Trim Objects to Extrapolated Edges for further information.
Press the down arrow key and select Undo to undo the last action.
Press the down arrow key and select Extend to trim objects to extrapolated edges.
Press the down arrow key and select No extend to trim objects to intersecting objects. Refer to Extend Objects to Intersecting Objects for further information.
