Press the down arrow key and select dElta to change the length of objects with a specified delta length. Refer to Change Length with Specified Delta Length for further information.
Press the down arrow key and select Length to display the length of the currently selected object on the Status bar.
Press the down arrow key and select Percent to change the length of objects with a specified percentage. Refer to Change Length with Specified Percentage for further information.
Press the down arrow key and select Total to change the length of objects with a specified total length. Refer to Change Length with Specified Total Length for further information.
Press the down arrow key and select Undo to the last action.
Press the down arrow key and select Angle to change the length of objects with a specified angle length.
Press the down arrow ley and select Length to display the length of the currently selected object on the Status bar.
Press the down arrow key and select dYnamic to dynamically change the length of objects. Refer to Change Length Dynamically for further information.
Press the down arrow key and select Angle to change the length of objects with a specified total angle length.
