Press the down arrow key and select Delete to specify deletion options for the source objects after offsetting.
Input Y at the prompt and press Enter to delete the source objects or input N at the prompt and press Enter to retain the source objects.
Press the down arrow key and select Layer to offset objects to a picture owner or original object layer. Refer to Offset Objects to Picture Owner or Original Object Layer for further information.
Press the down arrow key and select Multiple to offset the selected object multiple times.
Press the down arrow key and select Through to offset objects with a specified a through point. Refer to Offset Objects with Specified Through Point for further information.
Press the down arrow key and select To point to offset objects with a specified point.
Press the down arrow key and select Undo to undo the last action.
