Objects can also be rotated by manipulating grips. Refer to Rotate Objects using Grip Points for further information.
Press the down arrow key and select Base angle to rotate objects around a specified base angle. Refer to Rotate Objects around Base Angle for further information.
Press the down arrow key and select Copy to create a copy of the rotated objects.
Press the down arrow key and select Angle to specify the rotation angle of the objects.
Press the down arrow key and select Base angle to specify the base angle of the objects.
