Press the down arrow key and select Basepoint to specify the basepoint relative to which the grip points are stretched.
Press the down arrow key and select Displacement to stretch the selected objects in relation to the zero point of the drawing. The stretch position is determined by the position of the cursor in relation to the zero point of the user coordinate system.
Press the down arrow key and select Polygon to stretch objects using a polygon selection. Refer to Stretch Objects with Polygon Selection for further information.
Press the down arrow key and select Close to end the polygon creation process.
