DRAW
Add and Modify Drawing Objects
: Select Objects
Select Objects
Click to identify an object for selection.
Alternatively, a box can be drawn to select multiple objects.
To create a box in which all objects completely enclosed are selected, click the draw canvas and move the cursor from left to right. Click to confirm the selection.
To create a box in which all objects fully or partially enclosed are selected, click the drawing canvas and move the cursor from right to left. Click to confirm the selection.
The
Properties
window allows the user to define multiple selection mode or single selection mode. Refer to
Properties
for further information.
Select an object to display the grip points. Refer to
Modify Objects using Grip Points
To deselect all selected objects, press
Escape
To deselect a single object, hold down
Shift
and either click it or draw a box round it.
If required, the application can be configured so that the user must hold down Shift to select additional objects. Refer to
Drafting Options
Move Selected Objects
To move a selected object, click to identify the object and drag the object to a new position.
Multiple objects are moved as a group. The currently selected object is moved to the identified position, the relative position of all other selected objects is maintained.
Functionality is available to move objects in other ways. Refer to
Move Objects using Grip Points
and
Move Objects
