Input values in the dimension fields and press Enter or click to identify the first corner of the rectangle.
Input values in the dimension fields and press Enter or click to identify the opposite corner of the rectangle.
Throughout the rectangle creation process the user can press ESC to cancel the command. Additional functionality is also available.
Input values in the dimension fields and press Enter or click to identify the centre of the rectangle.
Input a dimensional value in the field and press Enter or move the cursor left or right to define the width of the rectangle. Click to confirm the required width.
Input a dimensional value in the field and press Enter or move the cursor up or down to define the height of the rectangle. Click to confirm the required height.
Input a value in the dimension field and press Enter. The radius is applied to all rectangles drawn in the session.
Input values in the dimension fields and press Enter or click to identify the first corner of the first axis of the diamond.
Input a dimensional value in the field and press Enter or click to define the length of the first axis of the diamond.
Input a dimensional value in the field and press Enter or click to define the length of the second axis of the diamond.
Throughout the diamond creation process the user can press ESC to cancel the command. Additional functionality is also available.
Input values in the dimension fields and press Enter or click to identify the centre point of the diamond.
