DRAW User Guide
Add and Modify Drawing Objects : Add Construction Lines : Add Ray Lines
To add a ray line, on the Draw tab, in the Construct group, click Ray Line.
The user is prompted to Specify insertion point or <Finish>
Input values in the dimension fields and press Enter or click to identify the insertion point for the ray line.
The user is then prompted to Specify direction point or <Finish>
Input values in the dimension fields and press Enter or click to identify the direction of the ray line. The ray line is drawn in the specified direction.
Input F at the prompt and press Enter to end the command.
Throughout the ray line creation process the user can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Undo to undo the last action.
